Missing something simple
Kevin Mahoney
I am sure that I am missing something here or in the book but.....If I am tuning my amp and/or antenna tuner how do I send a signal out besides using my voice on SSB or a key? (6300)
Tune Button
On the TX Panel...right under the power output and SWR meter is a button labeled "TUNE" press it and it will toggle a tune signal on and off. It is centered at zero-beat on SSB.
You can set the "tune power output" in the Settings>Radio Setup>Transmit tab...
Ken - NM9P0 -
Can I do it without the built in ATU doing it's job?0
Click on the TUNE button in the TX panel on the right in SmartSDR.
You can adjust the TUNE power with the RF Power slide while transmitting or in advance at the Settings=>Radio Setup=>Transmit screen... Tune Power is at the bottom of that frame.
Mickey N4MB0 -
wow0
The ATU button activates the internal tuner and puts it in tune mode. If you want to run without the internal tuner, hit the BYP (bypass) button . Then if you hit TUNE it just sends out a tuning carrier.
Clicking on BYP bypasses the tuner.0
got it, great help, thaks0
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 745 Maestro
- 41 FlexControl
- 720 Genius Products
- 387 Power Genius XL Amplifier
- 249 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
