Missing something simple
Kevin Mahoney
Kevin Mahoney Member ✭✭
I am sure that I am missing something here or in the book but.....If I am tuning my amp and/or antenna tuner how do I send a signal out besides using my voice on SSB or a key? (6300)
  • [Deleted User]
    edited April 2020
    Tune Button
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    On the TX Panel...right under the power output and SWR meter is a button labeled "TUNE"   press it and it will toggle a tune signal on and off.  It is centered at zero-beat on SSB.
    You can set the "tune power output" in the Settings>Radio Setup>Transmit tab...
    Ken - NM9P
  • Kevin Mahoney
    Can I do it without the built in ATU doing it's job?
  • Mickey N4MB
    Mickey N4MB Member
    edited December 2016
    Click on the TUNE button in the TX panel on the right in SmartSDR.
    You can adjust the TUNE power with the RF Power slide while transmitting or in advance at the Settings=>Radio Setup=>Transmit screen... Tune Power is at the bottom of that frame.
    Mickey N4MB
  • Steve N4LQ
    Steve N4LQ Member ✭✭
    edited September 2015
    wow
  • Ken - NM9P
    The ATU button activates the internal tuner and puts it in tune mode.  If you want to run without the internal tuner, hit the BYP (bypass) button .  Then if you hit TUNE it just sends out a tuning carrier.
  • Mickey N4MB
    Mickey N4MB Member
    Clicking on BYP bypasses the tuner.
  • Kevin Mahoney
    edited October 2015
    got it, great help, thaks
