starting CWX will cause the Flex Control to stop working and require the computer to rebooted before
James Kennedy-WU5E
Flex Control stop working when I start CWX
Don't see the problem here. Flex 6500, Windows 7, Flex control on powered USB hub. Any more details?
here cwx no problem win 7 flex 6500 with or without external cw keyer .sounds like your computer has moved your USB ports around or you have same name usb ports active. look there please0
No problem here.... Its been working gud since v1.3 came out... 6500 W70
Have not seem that here. Com port Problem with Flexcontrol?0
Conditions are Win 7 Home. FLEX 65000
My 6300 on a Win 8.1 box version 1.3 of ssdr and flexcontrol - no similar problems.
Don KF7DS
I am classifying this problem as "not a problem" until a reproducible procedure for making this problem occur is found since no one else is confirming it.0
Does the problem occur after transmitting using CWX?0
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
