starting CWX will cause the Flex Control to stop working and require the computer to rebooted before
Flex Control stop working when I start CWX
  • Dave - WB5NHL
    Dave - WB5NHL Member ✭✭
    edited January 2018
    Don't see the problem here.  Flex 6500, Windows 7, Flex control on powered USB hub. Any more details?
  • np2g
    np2g Member ✭✭
    edited November 2015
    here cwx no problem  win 7  flex 6500 with or without   external cw keyer .sounds like your computer has moved your USB ports around   or you have same name usb ports active. look there please
  • k0eoo
    k0eoo Member ✭✭
    edited March 2017
    No problem here....  Its been working gud since v1.3 came out...  6500 W7
  • Jim K4JAF
    Jim K4JAF Member ✭✭
    edited January 2018
    Have not seem that here.  Com port Problem with Flexcontrol?
  • James Kennedy-WU5E
    James Kennedy-WU5E Member ✭✭
    edited June 2020
    Conditions are Win 7 Home. FLEX 6500
  • Don Singer
    Don Singer Member
    edited September 2014
    My 6300 on a Win 8.1 box version 1.3 of ssdr and flexcontrol - no similar problems.
    Don KF7DS
  • Tim - W4TME
    edited March 2017
    I am classifying this problem as "not a problem" until a reproducible procedure for making this problem occur is found since no one else is confirming it.
  • K2CM
    K2CM Member ✭✭
    edited September 2019
    Does the problem occur after transmitting using CWX?
