starting CWX will cause the Flex Control to stop working and require the computer to rebooted before
James Kennedy-WU5E
Member ✭✭✭
Flex Control stop working when I start CWX
Don't see the problem here. Flex 6500, Windows 7, Flex control on powered USB hub. Any more details?
here cwx no problem win 7 flex 6500 with or without external cw keyer .sounds like your computer has moved your USB ports around or you have same name usb ports active. look there please0
No problem here.... Its been working gud since v1.3 came out... 6500 W70
Have not seem that here. Com port Problem with Flexcontrol?0
Conditions are Win 7 Home. FLEX 65000
My 6300 on a Win 8.1 box version 1.3 of ssdr and flexcontrol - no similar problems.
Don KF7DS
I am classifying this problem as "not a problem" until a reproducible procedure for making this problem occur is found since no one else is confirming it.0
Does the problem occur after transmitting using CWX?0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
