6300 v1.3 not keying amp
Andreas Junge
After upgrading to v1.3 the 6300 stopped keying the amp (RCA connector).
I have enabled "RCA TX1" in the setup.
73, Andreas, N6NU
73, Andreas, N6NU
Check that you have the Amp plugged into the correct RCA on the back of the 6300. Very easy error to make. 73s Jim K4JAF0
Did you reboot the 6300?0
It worked with the previous version. I have not touched the cable.0
Yes. After the installation of 1.3. I also turned it off a few times when not using the radio. Maybe I'll try to unplug the power cable.0
Are you otherwise transmitting cw ok? Had to ask.
Yes.0
OK - I pulled the power all the way. Now it's keying ...
Thanks for all the input.
73, Andreas, N6NU0
- 112 SmartSDR+
- 944 Maestro
