6300 v1.3 not keying amp
Andreas Junge
Andreas Junge Member ✭✭
After upgrading to v1.3 the 6300 stopped keying the amp (RCA connector).
I have enabled "RCA TX1" in the setup.
73, Andreas, N6NU
  • Jim K4JAF
    Jim K4JAF Member ✭✭
    edited April 2019
    Check that you have the Amp plugged into the correct RCA on the back of the 6300.  Very easy error to make.  73s Jim K4JAF
  • Steve N4LQ
    Steve N4LQ Member ✭✭
    edited April 2019
    Did you reboot the 6300?
  • Andreas Junge
    edited December 2016
    It worked with the previous version. I have not touched the cable.
  • Andreas Junge
    Yes. After the installation of 1.3. I also turned it off a few times when not using the radio. Maybe I'll try to unplug the power cable.
  • Steve N4LQ
    edited September 2015
    Are you otherwise transmitting cw ok? Had to ask.
  • Andreas Junge
    edited April 2019
    Yes.
  • Andreas Junge
    edited April 2019
    OK - I pulled the power all the way. Now it's keying ...
    Thanks for all the input.
    73, Andreas, N6NU
