SmartSDR v3.3.32 and the SmartSDR v3.3.32 Release Notes | SmartSDR v2.8.0 and the SmartSDR v2.8.0 Release Notes
Power Genius XL Utility v3.6.24 and the Power Genius XL Release Notes v3.6.24
Tuner Genius XL Utility v1.1.8 and the Tuner Genius XL Release Notes v1.1.8
6300 v1.3 not keying amp
Andreas Junge
After upgrading to v1.3 the 6300 stopped keying the amp (RCA connector).
I have enabled "RCA TX1" in the setup.
73, Andreas, N6NU
73, Andreas, N6NU
Check that you have the Amp plugged into the correct RCA on the back of the 6300. Very easy error to make. 73s Jim K4JAF0
Did you reboot the 6300?0
It worked with the previous version. I have not touched the cable.0
Yes. After the installation of 1.3. I also turned it off a few times when not using the radio. Maybe I'll try to unplug the power cable.0
Are you otherwise transmitting cw ok? Had to ask.
Yes.0
OK - I pulled the power all the way. Now it's keying ...
Thanks for all the input.
73, Andreas, N6NU0
- 18.7K All Categories
- 141 Community Topics
- 2K New Ideas
- 295 The Flea Market
- 6.3K Software
- 5.4K SmartSDR for Windows
- 95 SmartSDR for Maestro and M models
- 218 SmartSDR for Mac
- 188 SmartSDR for iOS
- 181 SmartSDR CAT
- 116 DAX
- 321 SmartSDR API
- 7.9K Radios and Accessories
- 6.4K FLEX-6000 Signature Series
- 636 Maestro
- 30 FlexControl
- 780 FLEX Series (Legacy) Radios
- 435 Genius Products
- 253 Power Genius XL Amplifier
- 158 Tuner Genius XL
- 24 Antenna Genius
- 124 Shack Infrastructure
- 79 Networking
- 216 Remote Operation (SmartLink)
- 94 Contesting
- 319 Peripherals & Station Integration
- 89 Amateur Radio Interests
- 602 Third-Party Software
