ANT1 gone
Greg
I had 4 panadapters open and I think 3 slices. All using ANT1. I clicked on a spot on DXLabs spot collector and the slice tuned to the right frequency but I lost all receive. ANT1 was still selected as the TX antenna but nothing showed in any of the slices as the RX antenna. I checked the ANT box for each panadapter and ANT1 was not an option to select on any of them. I had to shut down SmartSDR and cycle the power on the radio and restart SSDR. Things came back to normal then. Just reporting this as I don't recall seeing this reported before. 73 Greg
FLEX-6500? If so, you ran out of slice resources when you tried to do the band change via CAT. This should be fixed in SmartSDR v1.10
This is on a 6700 Tim.0
Why is this solved?0
Because you reported a problem that has been resolved with the upcoming release.0
OK...I did not see anything that indicated that. Thanks.0
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
