ANT1 gone
Greg
Greg Member ✭✭
edited March 2017 in SmartSDR for Windows
I had 4 panadapters open and I think 3 slices. All using ANT1. I clicked on a spot on DXLabs spot collector and the slice tuned to the right frequency but I lost all receive. ANT1 was still selected as the TX antenna but nothing showed in any of the slices as the RX antenna. I checked the ANT box for each panadapter and ANT1 was not an option to select on any of them. I had to shut down SmartSDR and cycle the power on the radio and restart SSDR. Things came back to normal then. Just reporting this as I don't recall seeing this reported before. 73 Greg
    edited March 2017
    FLEX-6500? If so, you ran out of slice resources when you tried to do the band change via CAT. This should be fixed in SmartSDR v1.1
  • Greg
    Greg Member ✭✭
    edited January 2014
    This is on a 6700 Tim.
  • Greg
    Greg Member ✭✭
    edited March 2017
    Why is this solved?
    edited December 2016
    Because you reported a problem that has been resolved with the upcoming release.
  • Greg
    Greg Member ✭✭
    edited January 2014
    OK...I did not see anything that indicated that. Thanks.
