CONTEST OR GENERAL LOGGING PROGRAMS FOR FLEX RADIOS
Looking for a logging program that will allow the use of more then two active slices. As a work around a logging program that will allow more then one instance to run on the same computer. MMTTY my RTTY digital decoding program allows this. Another possibility to run two or three different logging programs on the same computer. I am hoping to get some guidance before having to experiment. I am currently using N1MM with MMTTY to decode RTTY. The N1MM program is limited to two slices and only one instance of the N1MM program to run. AA2MF
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptions -
SDC Contest, a N1MM type contest log on steroids, will allow for as many Slices as you have access to. No need for other s/w as it has Flex API interfacing, its own RTTY module that is better than MMTTY and pretty quick support if you need it.
Hmm, decided to try this program.
Couple questions: Where is the settings for a dark mode?
Under FlexRadio i can see 2 panadapters open
I have 2 JTDX opened and when click on the callsign on this example 50 or 18Mhz, callsign going to a "Callsign" field , but Frequency on the top stays on 18Mhz.
What do I miss?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsEdit, Preferences, General
- 198 SmartSDR+
- 323 Shack Infrastructure
- 228 Networking
