SmartLink crashing at connection?
2»
  • KI5RLR
    Why not allow an option in SSDR where the user can type in a Private IP address where the radio can be located?
    Mike-VA3MW admin
    edited October 2023
    We greatly appreciate your valuable input and feedback. Your suggestions are incredibly important to us, and we want you to know that we're listening. Don't forget to upvote this request in the "New Ideas" area of this community.
    Rest assured that your input will be taken into consideration as we shape the future of our offerings. Together, we're working towards a better, more innovative experience.
    Thank you for being a part of our journey to make FlexRadio even better. Stay tuned for exciting updates on the horizon!
  • KI5RLR
    Mike - That last question was for Eric. You sure stepped in and cut him off quick. You remind me of a used car salesman the more you talk. Where did they find you?
    Mike any given day:
    Mike on same subject the next week:
    The door is closed on the discussion regarding this. All I can say is that if you urgently require a plan B that isn't SmartLink, it will have to be something you do with the tools you have available today. There are other things higher up the priority list. I'm sharing that just so the timeline is understood, that is all.
  • Eric-KE5DTO
    I feel like I covered the why in the post quoted above.
    tl;dr We don't want to make it easy for users to put the unauthenticated interface of the radio on the open internet.
  • KI5RLR
    Right, that's why I said "Why not allow an option in SSDR where the user can type in a ***Private IP*** address where the radio can be located?" See below chart for addresses that would be accepted.
    ***Private IP Address Ranges***
    Class A: 10.0. 0.0 to 10.255. 255.255.
    Class B: 172.16. 0.0 to 172.31. 255.255.
    Class C: 192.168. 0.0 to 192.168. 255.255.
  • KI5RLR
    Eric - I received your 1:26pm response. When I began to reply (and thank you) your response was no longer there.
  • KI5RLR
    Thanks Eric, I appreciate you hearing me out. I am not a software engineer by any means, but I am imagining some sort of 'appropriate messaging' to be an error callout next to the 'Private IP field' that would alert the user to (and block the acceptance of) a non Private IP Address. It might even have a small 'i' or '?' next to the field that says defines Private IP ranges as 'xyz'.
    I don't know how to follow 'SMART-9790' and I know you can't make any promises, in fact I imagine this idea will be DOA. I do however appreciate you taking the time to listen and document exactly what I was getting at. Clearly most respondents on this post, despite their best efforts along with mine, did not understand what I was requesting.
    I will mark this question as answered.
    73 Clif KI5RLR
  • KI5RLR
    Ah! When I marked your first response 'Yes' to 'Did this answer the question?' it moved your post to the top of the thread. So I clicked 'yes' and started to craft my response, glancing up at your message for reference... and it was gone. 😂
    73 Clif KI5RLR
