Popping sound
Hi all,
I have an annoying popping sound both on headset and PC speakers. When I move the VFO it happen mostly when getting to the edge of the panadapter, it move together with the VFO. You can listen to it here: https://youtube.com/live/AySvdTH_BRE
My system is a Win11 GamePC with a ryzen7 5800X, 128Gb DDR4, SSD M2 (gaming) and a RTX 2060 OC. The router is a 1GLan Cisco and all Cables are Cat6.
I tried to change router, reduce the PC load, disable all companion software, use another PC in the network and as last resort the radio Factory Reset but the issue is still there.
Any suggestion?
Max IU4JNR
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThe popping sound is related to your network communications and it is actual packet loss.
It likely is not related directly to the radio or the PC since they all seem ok. And, I do see that you changed the router. If the router is a 1GB/Sec router, is there any chance you can test with a 100mb/sec router as we have seen that 1GB routers are not very good when dealing with 100mb LAN.
Are you using WiFi at all ?
Hello Mike, thanks for prompt reply. I do not use wifi, just wired. I will reduce the max speed as per your direction both on the cisco router and on the lan card which is a 2.5gb killer. I let you know.
Thank you, Max IU4JNR
hello Mike,
I’ve reduced the speed as suggested and then, in little steps, I applied other changes to my network adapter. With the network analysis tool, the latency is stable <1ms. However, there is still a little “popping and crackling” effect in the headphone (less in the pc speakers) which arise when, moving the VFO and reaching the edge of panadapter, it move following the vfo. Actually it seems I have mitigated a little but it is still there.
Maybe it is a kind of “eye floaters”, nothing really important which I will get used to.
Is to be mentioned however that I own other 2 advanced SDR of different brands which share the same network but not at the same time (I have just 1 set of antennas) and I don’t experience crackling/popping issues on both of them, nor other latency issues.
Max IU4JNR
- 688 The Flea Market
- 105 Aurora
