How do I get WSJT to activate transmit for 6700
I have WSJT running on my win 10 pro 64 bit PC. I can decode incoming signals and CAT control works however when I press the "Test PTT" button in WSJT setting I see my COM4 port under CAT v3.3.33 show WSJT but the 6700 does not click and therefore no transmission for FT8.
Using Smart SDR v3.3.33
Here are some screen shots.
Please help me figure out why I cannot transmit even though it appears that WSJT is communicating with COM4 port of SmartSDR CAT.
Rich
KB5EDR
  • Rich Roby
    Rich Roby Member ✭✭
    I figured it out!!!
    Above you will notice that I changed the PTT method from RTS to CAT and it works!!
    Now I am off to the world of FT8 on my Flex.
    Yes, that is the fix.
    RTX and DTR are hardware levels on a USB / Serial port, which you are not using since you are using IP addressing which is actually preferred.
    Once you moved to CAT you are now sending a computer command to the radio.
    Glad you figured it out.
