PC Stuck Issue Cannot Be Fixed While Resetting.
A possible solution, at least one that has worked for me a couple of times when corrupted boot files have prevented Windows from starting, is what Microsoft calls an' inplace upgrade'.
From the MS website: Inplace upgrade is a process wherein it will upgrade the device to the latest version and repair all issues without deleting any files, usually, it is used to repair corrupted system files, apps, and even incompatible drivers on the system.
Despite the name 'upgrade' it is best to use a Windows OS image of the exact version that you are on. Take that into account if you use the Media Creation Tool. An example of the inplace upgrade can be read at
How to perform an In-place Upgrade with Windows 10 Step-by-Step Guide - Microsoft Community
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsMy 2 cents (personally). If you can actually resolve the symptom by finding the actual problem, just buy a new hard drive and rebuild it from scratch.
Yes, it is a PITA, but you will be very happy with the result. And, yes, you will have to reinstall a few things. But it will be a clean system in a good known state.
Erik's ideas are good as well.
I tried to resolve the issue by restoring a previous system point ( source: https://digicruncher.com/resetting-this-pc-stuck/ ), But I don't know if this the permanent solution or n ot.0
resolved the problem with a clean install of windows 10
can the new V4.2 software run on my win 10 machine?0 -
Hi Jepley… unfortunately, with Microsoft ending support for Windows 10, and with the new drivers in v4.2, I would say it may work with Win10, but it's unlikely. I don't believe Flex recommends/provides support for SmartSDR running on Win10
Sorry.
- 694 The Flea Market
