PGXL and TGXL remote
How to install PGXL and TGXL remote? I don't see the PGXL and unable to connect when installing the Power Genius Utility. I took it for granted that is was just as easy to connect PGXL and TGXL remote as to connect the Flex6400. I don't have a computer by the radio but using the computer at my remote QTH for FW installations.
    At the moment, there is no perfect SmartLink solution. For the PGXL, it isn't a big issue since it is incorporated into SmartSDR. Putting the PGXL in standby essentially turns off the PGXL (just like turning off a TV).
    The TGXL is not yet incorporated and I can't really provide you with a status of timeline.
  • LA9BM
    LA9BM Member ✭✭
    It surprises me. There is no problem with SmartSDR so why isn't possible with the PGXL and TGXL software.
    The best answer I can provide is that it takes time and people to write the software to make it work and then test it.
    At the moment, there are higher priority projects.
  • HAMAD A71VV
    HAMAD A71VV Member ✭✭
    Hi Mike , any update?
    I am using my Mac laptop now as I can see Both TGXL & PGXL. The only issue is that I can't control the antennas ports via LAN when I am out of my home network?
    any idea on how can we sort it out?
    73's
    Hamad
    A71VV
    Nothing that I can mention at this time.
  • Dan Trainor
    Dan Trainor Member ✭✭✭
    edited July 2022
    These type if features usually appear in the MacOS version of SmartSDR first. Things like PGL-XL and TG-XL integration was first in MacOS version and progressing faster. So, I would look to that software for advances in Antenna Genius switching features over SmartLink WAN.
  • David Decoons, wo2x
    see below. This is from my smartphone. It can be done from any browser. ;-)
