DAX and CAT for RX inband 6600 sharing
IT9EQO
in Contesting
Hello to everybody,
We would like to use a FLEX 6600 in RX inband setup and share it in some PC on differents setup bands. We need to receive signals from 6600 in the same frequency of the inband RTX used on that band and sync the frequency of the RTX with one of four 6600slice . This is needed on 4 RTX/PC simultaneously on the four slices available on the 6600. someone did use this mode ?? Is possible to share by a smart sdr CAT the frequency data info in a different PC ? also for DAX ?? Hope explained well our need.
Thanks in advance, Antonello, IT9EQO.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi
Yes, you can as many computers with SmartSDR CAT (and DAX) as you like. Give it a try.
[{"insert":"Hi Mike!\nThanks for reply, you tell me that I can open simultaneously 4 smartSDR on 4 PC to have DAX and CAT from the same Flex 6600?\n"}]0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYou can run as many copies of SmartSDR CAT and DAX on as many computers as you wish (1/computer).
You can 1 copy of SmartSDR (the user GUI) on 1 computer at a time up to 2 computers using MultiFlex.
sorry, of course I did not explained well. We need to listen 4 frequency with 4 dax on 4 different PC and sync 4 CAT on the same 4 PC with relative 4 RTX. Configuration is 2 bands, i.e. 20 and 15, with 2 slice on each band to listen: on 20m inband frequency and run frequency, and on 15 m band (MULT station) can listen 2 frequency for double search and pounce .0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYou can listen to 4 frequencies on 2 different PCs. Not 4.
2 Slices on PC A
2 Slices on PC B
[{"insert":"Ok Mike, thanks a lot for the answer!\n"}]0
- 693 The Flea Market
