WNB automatically shutting off
DV2SXB
DV2SXB Member, Unconfirmed ✭
edited October 2021 in SmartSDR for Windows
Hello,
I am trying to use the WNB however the application I am using can scan multiple frequencies/bands. Even though I am only "scanning" one at the moment, each cycle removes the WNB setting.
How can I make the WNB remain enabled when using an app that like this?
Software is RMS Tri-Mode with Ardop. (for Winlink)
Additional observation:
NB stays enabled, but NB is not suitable for my operating location.
WNB continues to disable automatically.
    The Wide Noise Blanker involves a lot of processing power since it samples a LOT of radio spectrum in order to make it function. If you listen, it takes about 1/2 sec to engage in order to build the sample data.
    It is really not something that would work well with scanning.
  • DV2SXB
    edited October 2021
    Thank you for the reply Mike. The latency and working well wasn't as much of my concern. It automatically turns off every cycle. I was hoping for a way to keep it enabled per band or per frequency. If it's not possible, that's fine.
    I will see if I can find a work around for the situation. That would depend on the capabilities of the software I'm trying to use.
