Antenna Genius is there a simple Remote app to control the AG without use of Node-Red?
I simply want a tool set like the one with PGXL
where I can control the Antenna Genius while operating away from my shack
I do not want an elaborate tools set that I would have to build like Node-Red
Just a simple app, please
Steve KG5VK
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThe only tool available now is the Windows Antenna Genius application that is for Windows only.
The AG will follow the radio based on band assignments and the last antenna selected for the band and it will do this without the PC software running.
Today, the only solution available is a customized NodeRed solution or to do a remote desktop connection to PC that has the AG software. While this sounds difficult it is a very practical method for long term remote optional and it helps build a foundation for the longer term for your remote radio operation.
tldr; No, not at this time.
Node Red can run on a Pi on your network and is simple to get up and running. The flows for the Flex radio, Power Genius and Tuner Genius, as well as the 4O3A 2x8 switch are already written and you only need to set IP addresses. I can control the amp and tuner from my smartphone.
You can make the Node Red dash as simple or as detailed as needed.
Thanks guys I will sit down in a week or so and get some Node-Red work done
Cheers!
Steve
KG5VK
Let us know if you need help. The Node Red for Ham Radio group has a WiKi for setting up Node Red server on a Pi. Also we have a file section that has a good Antenna Genius flow (think of programming instructions for Node Red). Conny, N5HC and I wrote it.
Dave
Thank you
steve kg5vk
