where is the secret hiding place for FlexSatPC ??
James Kennedy-WU5E
Member ✭✭✭
I want to use my Flex 6600 for satellite also , I see dropbox link to download it where is the secret hiding place for FlexSatPC?
Jim
WU5E
Jim
WU5E
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Jim
You use the normal SATpc32.
In SmartSDR CAT, create 2 Serial ports. One for Slice A - VHF and one for Slice B for VHF.
Then, in SATpc32 you want to create Radio 1 to address Slice A Serial Port and Radio 2 to address Slice B's radio port.
For each radio, select the Radio as a Kenwood TS2000 and you can use any baud rate, but 4800 is fast enough.
I don't have it fully setup yet, but that should work.
I'm not sure about how to setup Autom Rx/Tx change and I think that you can leave Satellite Mode unchecked.
I'm sure there are others here that can show you their setup.
Mike1 -
i have a register copy of SATPC32 from amsat, thanks for the reply , this is pissing me off, guys keep putting the same link that PDF file, I email the Author he might respond . I did build two comports for SATPC32 and they are working. Im thinking that since the name Flex was in the name of the software this is why it's not on your site.
there should be a API to install. thanks for your time.0 -
Jim,
Contact Dave, W0DHB, the author for a copy of FlexSatPC32. I don't want to list his email here without his permission but good in QRZ.
Mack
W4AX0
