iOS SmartSDR Has Feedback on Transmitted Audio
Thanks, Chuck
Chuck, it seems you did not yet maintain the Microphone Threshold slider in the left audio menu, right?
This is necessary. A value around 0.4 should be good but it would be best to follow the description in the Manual to find the best value for your individual device.
Marcus, DL8MRE
There are several of us that have talked about this bad TX audio issue and seems to have started at least with my station when I updated to version 13 of IOS.
I have found that dropping down the Audio level almost all the way down < -3 in the "audio" settings for TX in the top Left hand menu options turn OFF the Processor compression and set your MIC audio in the TX tab so your down to about -5 to -10 DB ALC.
This does NOT fix the distortion issue BUT it makes it so at least it is usable
Bret
wx7y
Bret, did you maintain the Mic Threshold slider yet?
Marcus
yes I sure did it is way down too still distorted and hi TX audio
Bret
WX7Y0 -
Thanks, Marcus. That seemed to help considerably. I tweaked it before, but didn't get the result until I went to the extreme. Seems to work best between 0.9 and 1 for me.0
And what is your current threshold value?0
That seems to be high but if it’s working, it’s working.
However, if you want, you can also see if the following three settings will further increase the audio quality:
- Under the Flex-6xxx tab -> Phone there is a Mic Bias and Mic boost option. Usually both can be turned off.
- In the right menu, the slider right from the mike selection (iPad or iPhone) can be used to adjust the general audio level
- and finally, the microphone volume adjustment slider in the left audio menu.
On all of my devices, including older iPads and the newest iPad Pros and iPhones under the newest iOS I achieved excellent audio quality by maintaining these settings, including the threshold slider. Also, when using either the old or new AirPods.
Keep in mind that except for the settings in the left audio menu, all values are stored on the Radio. For those, if you require different values for different clients (iOS App and Windows Software) better use profiles to store and recall them for each client individually.
Marcus, DL8MRE0 -
the threshold is 0.8, Mic Volume is -5, I will test more tomorrow on our 80 meter NET where i can get many different people giving there opinion.
My phone did another update this morning so Audio may have fixed itself, I no longer see it picking up every little bit of noise and slamming the ALC audio levels like it was and the ton's of feed back when trying to monitor my self on another Radio so it may be back to normal.
will know in the morning at any rate.
Thanks Marcus
Bret
WX7Y
MIC Boost was on
I think that took care of it
looks a lot better
Thanks Marcus
Bret
Marcus, after this mornings net and it was reported to me that my Audio was really good so looks like the IOS update yesterday morning did the trick
Thanks for you help
Bret
WX7Y
I have just bought this app for the second time, i was putting my bad audio down to an under powered iphone
so i bought an iphone 15 pro max yesterday (i don't even like iphone.. but that's a different story)
i bought the smartsdr app again and no matter what i do , move all the sliders left and right, disable boost etc, the audio still sounds horrific
I really want this to work (especially after buying the new phone), has anyone got any more hints on what i coudl be doing wrong?
I've been 1 hour listening to myself on a web sdr and i'm still sounding as bad as ever .smartsdr for windows is fine, i have an awsome home network here etc
it must be my imcompetence, but app is useless to me unless i can tx clearly…
any help or pointers appreciated
maybe pricing has changed since I bought th app. At that time, all the devices on the same apple account were covered by the same purchase of the app. Basically there are two transmit volume controls, one on the left side of the screen and one on the right side.
Hi John,
Same account but i got a refund the first time hence my buying agian.
Yes I found all the settings on left and right I didn't have any luck,however this morning I discovered that the audio is fine if i switch off the processor, not sure why but with processor on (even at normal) the audio is diabolic.
i can live with processor off but i thought the flex did cessb so i'm puzzled as to why it doesn't work with iPhone (works fine with windows)0 -
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI have no audio issues when I used it on my iPhone 15 Pro with my Airpods. Yes, the audio is a bit crisp, but there is nothing wrong with it.
The first thing I always ask is what is the Mic Level meter doing?
In this example, I have PROC turned on and the Mic Level peaking at about -5db.
The Mic Level Meter is the meter you have to 100% pay attention to when operating SSB. If you overdrive the MIC your audio can be distorted and that will get transmitted on the air.
And, while you are testing, make sure the TX EQ is OFF until you get the distortion fixed.
See how that works for you and let us know.
Hi @Mike-VA3MW ,
Thanks for your reply, your mention of air pods caught my attention..
I was trying just talking to the phone itself,, i pluged in a usb headset and it was perfect!
I do have good success using SmartSDR with just a laptop and no headset so was trying the same with the iPhone on loudspeaker mode,, not a runner it seems.Tnx a mill
Open the Left menu and select Audio. This will show the iPhone Audio as well as other modes. Scroll down and insure the 'Local Audio Monitor' slider is all the way to the left or off. I had the same problem in my truck.
Hope this helps!
73's Rick…KJ5WO
I had difficulty in finding how to turn off audio monitoring on my iPhone. Rick’s suggestion to scroll down from the Audio menu allowed me to see the control. It isn’t obvious that there are more settings off the screen. 🤪0
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
