Slice master does't work for CW Skimmer
Henry Sung
Hi,
I'm now using CW Skimmer with SDR-Bridge.
It works so well however I try to use Slice master instead of SDR-Bridge.
Unfortunately it dose not work with CW Skimmer.
The error message is "Audio device for DAXIQ channel is missing. daxiq=1"
Is there anyone who knows why this message is happen ?
Thanks,
Henry
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsDo you have an IQ stream assigned to DAXIQ 1?0 -
Yes, IQ stream is properly working. As I mentioned with SDR-Bridge CW skimmer works no problems.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Henry, just wanted to make 100%. I assume you have restarted DAX just in case there was an issue with the connection to Slice Master?
I have had it working just fine for me with only SliceMaster and SliceMaster auto configured it.
Henry,
The problem is with your DAXIQ driver installation. That error message is Slice Master's way of telling you that your 'DAX IQ RX 1' driver is missing.
--Don
I'm still fixing these DAX IQ errors, for anyone that needs help, in the #Flexradio IRC channel.
the link is in my signature. If your willing to have it fixed, I'm willing to fix it. BTW, it's a PC/OS problem, not a SmartSDR problem. Come see me in the channel for more information.For real-time discussions
User created documentation.
Volunteer!!73, Jay - NO5J
I tried to uninstall all dax drivers on CMD line and re-install again. But I can not fix of this issue.
- 104 Aurora
