Maestro Waterfall Disappears after 5-10 seconds
Jim Branson
Jim Branson Member ✭✭
edited April 2019 in Maestro
My Maestro waterfall disappears 5-10 seconds after connecting to the Flex-6600.  The audio goes away with the waterfall. Meters stay on the screen.  Same result if using battery or power supply.   Now I'm getting an error message of "Waiting on Hardware Initialization (W, X,Y, Z, K,XTS,YTS, CSN, ETH)".   Everything works fine on the PC.  Just issues with the Maestro.
V2.39
218-3389-0100-7001
Any suggestions?
Jim N0LBY
  • ka7gzr
    ka7gzr Member ✭✭
    edited August 2018
    I often get this if the battery partially is discharged. Try a fully charged battery.
    Jim
    Ka7gzr
  • Jim Branson
    edited April 2019
    I let the unit set for a 1/2 hour after getting the error message.  I rebooted then pulled the battery and plugged in the power supply.   Same result.  The waterfall and audio disappears after 5-10 seconds.
    Jim N0LBY
    edited August 2018
    This is often related to a low or dead battery, either the internal battery or the add on battery (or both).  Leave it plugged in overnight and try in the morning.  Make sure the external power supple is actually plugged in and operational.  Sometimes my cord works its way out.
  • Jim Branson
    edited August 2018
    That fixed the problem.  I left it plugged in overnight.  The internal battery must have been low.
    Thanks for the help.
    Jim
    N0LBY
