selecting radio at start up
DonE
DonE Member ✭✭
When I click on the radio to select, the update window comes up if I click on update it will remove the ver, I have which is v2.1.32 ( just got my 6400 today ) and load a previous one ( which did not do ) where do I go from here?
    edited April 2018
    I suspect you have a CD with version 2.1.32 and a radio that has the latest version of SmartSDR.  I recommend downloading the latest version of SmartSDR (v2.1.33) and running that on your FLEX-6400.  If it asks you to update the firmware after you connect to the radio, do so.
    Here is the link to download the latest SmartSDR for Window software
    http://www.flexradio.com/downloads/smartsdr_v2-1-33_installer-exe/
    If you have already installed a previous version of SmartSDR on your PC, you should remove it before installing v2.1.33
  • DonE
    DonE Member ✭✭
    edited May 2018
    Tim just got the 6400 this evening and loaded the cd which says it is 2.1.32 should I download what I loaded before I download the 2.1.33?
    edited April 2018
    If you have installed SmartSDR v2.1.32 on your PC - uninstall it and reboot your PC
    Download SmartSDR v2.1.33 (link previous provided), Install it and reboot when prompted.
    Run SmartSDR v2.1.33 and if the Chooser indicates that the radio needs to be updated, update it.  If not, select it and connect to your radio.
  • DonE
    DonE Member ✭✭
    edited May 2018
    meant to say uninstall rather than downloads!
    edited April 2018
    Yes, see the instructions I just provided above.
  • DonE
    DonE Member ✭✭
    edited April 2018
    Thanks Tim that got me on
