Windows 10 update disabled Virtual Serial Port
Takeshi Yamada
I happened updated Windows 10 to ver. 1607 and knew that FlexRadio Virtual Serial Port does not work. It returns "Code:19. Registry information is incomplete or broken and can't start device" (description may be different as mine shows message in Japanese).
Are there any way to fix this other than back to the previous Win10 version? I need this version to have run Xlaunch (X window system) to connect to Unix system.
Hi Takeshi, under "Programs and Features" find "Flex Radio Systems FlexVSP", highlight, right click and select "Repair". Then reboot and hopefully your issue will be resolved. This happened to me today as well and the repair worked for me.
Cal/N3CAL
4 -
I had to revert back to the previous update to get the same problem solved.
Jim/ WU5E
Hi Cal, your solution worked for me after the 10th Anniversary update. No other issues with smart sdr after update except the FlexVSP repair. Stan0
Thank you Cal for your information. Unfortunately, I reverted to 1511 just before reading your information. I retried to update to 1607 again, but it does not work - cannot update to 1607 as of now. Anyway, I will try "repair" when I come across to this kind of problem next time.
Thank you!
Just do a full uninstall and reboot then reinstall smartSDR and reboot again, this worked on 3 different computers I use here that WIN10 update broke.
I didn't reset the radio so I didn't loose any of my configuration. took about 5 minutes to do it and no other problems.
73's
Bret
WX7Y
Thank goodness Microsoft is not in control of our automobiles.0
Yes Full Uninstall/Re-Install of SmartSDR has seemed to work each time when these problems pop up.
I first do a full Export of all of my profiles in SmartSDR then Uninstall SmartSDR and FlexVSP from the windows control panel then I just Re-Install SmartSDR and everything works perfect again.
My thinking regarding which way to solve the problem is, Do I want a repaired SmartSDR installation, or wouldn't I prefer a brand new installation. If I wreck my car, I know which solution I'd prefer. As long as I'm permitted to clean out the glove box and grab my toolbox out of the trunk, before sending the wreck off to the junkyard I'm ok with starting over with a brand new vehicle.
If you have backed up your profiles and memories, then you have all your possesions.
That new car smell will fade away soon enough.
Full Uninstall/Re-Install takes less time than cleaning out the garage.
I never felt the need to blame Chrysler for the wreckage either.
Must have been something "I" did.
73, Jay - NO5J0 -
By the way, there is an updated version of the "How to do a Complete uninstall of SmartSDR for Windows from your PC" guide, on the ZenDesk.
https://helpdesk.flexradio.com/hc/en-us/articles/204975589-How-to-do-a-Complete-uninstall-of-SmartSDR-for-Windows-from-your-PC
Thanks Tim!
Re-read it and see if you can spot the changes.
73, Jay - NO5J0 -
Jay, SmartSDR is not the program getting repaired! FlexRadio Systems FlexVSP is the program being repaired. Why touch SmartSDR when the issue is another program?
This issue was actually discussed just the other day and Flex's recommended resolution was a simple repair to Flex VSP . I was just trying to pass on that info since it worked for me. That thread can be viewed here:
https://community.flexradio.com/flexradio/topics/windows-10-update-strikes-again
Cal/N3CAL0 -
Cal
I'm glad you've got it fixed.
I've repaired FlexVSP in the past. Using the same method.
I don't advocate, junking the car, when complete repairs are possible.
I was mostly trying to point out that Tim has updated his guide, to include recommendations for handling the Win 10 Anniversary upgrade situation.
The first machine I upgraded had DAX and CAT/VSP issues. I tried replacing/repairing the broken parts, but in the end I did the Full Uninstall/Re-Install.
The second machine I did the Full Uninstall/Re-Install first. SmartSDR installed perfectly after the upgrade was through.
The third is doing the anniversary upgrade, right now, and it also got the Full Uninstall/Re-Install treatment first.
I didn't see Tim's updated guide, until after I did the first Anniversary upgrade.
I found it, by clicking on the link on the Zendesk, expecting only the old guide.
I knew that procedure would likely solve all the problems. If I'd seen that guide first, I'd have reported that the Win 10 upgrade, went perfectly.
I like the fact that I can get a brand new radio by reinstalling any and all of the released versions.
Nothing wrong with New.
Nothing wrong with Fixed just like New either.
We have a choice between a DIY Fix, and a DIY replacement.
Choice is good!
73, Jay - NO5J
- 685 The Flea Market
