Maestro slices
Bob G   W1GLV
Bob G W1GLV Member ✭✭
Radio - 6500 Software Ver. - 1.8.4 3 problems to report on the Maestro 1. When I initially turn the unit on, I get a pan adapter, spectral info and an empty slice flag. The radio was shutdown with a frequency of 14.076 for JT65 work. If I select the slice flag enumerator (A) sometimes it will correct itself and show the info the radio was shutdown with. 2. The XIT function does not work when a single slice is present. Selecting XIT with the red lite on, turning the frequency knob to displace the frequency causes the slice frequency to change. Adding a second slice on the same pan adapter, causes the XIT function to work normally. 3. On initial startup after selecting Ver. 1.8.4, the update info will read (3 of 4) please wait. After indicating approximately 1/4 of update the radio will start. Reverted back to version 1.7.32, everything is normal. Thanks
  • Al K0VM
    Al K0VM Member ✭✭✭
    Bob,
      Item 2.  New to 1.8, wIth a single slice open, the B knob will control the RIT or XIT of VFO A
    AL, K0VM
  • k3Tim
    k3Tim Member ✭✭✭
    1 + 3 sound like a WiFi / E-link error at startup. I've seen similar when I've been the network configuration around. #3 seems harmless although it causes one to pause in brief anxiety.
    Good luck on 1.7.32 it's 1.8.4 at the station here as items 1 & 3 are no-issue and #2 works as Al points out.
  • Bob G   W1GLV
    edited December 2016
    Not the case. !.7.3 starts up correctly everytime.
  • Bob G   W1GLV
    Is that documented anywhere?
  • Al K0VM
    Al K0VM Member ✭✭✭
    I think it should have been in the release notes but I don't see it .. It is in the change log included with 1.8.4.   I haven't looked in the user guide.
    AL, K0VM
  • WX7Y
    WX7Y Member ✭✭✭✭
    edited July 2016
    Did you try doing a factory reset?
    That may be the cure, it was for me anyway.
    Bret
    WX7Y
  • Bob G   W1GLV
    Thanks for the info.
