Improve NR (noise reduction) -- request to add another "DSP enhancements" item for NR to the road m
Per Geralds suggestion below here is an idea for NR. It was part of the "DSP enhancements" in V1.1 release in January 2014. Since that time there have been several comments and questions about its performance from both customers and FRS staff. Here are a few of the related links:
https://community.flexradio.com/flexradio/topics/is_the_reduction_in_the_nr_operation_a_new_feature
https://community.flexradio.com/flexradio/topics/ssdr_v1_2_1_noise_reduction_were_there_any_changes_...
https://community.flexradio.com/flexradio/topics/which_features_do_you_feel_work_marginally_that_we_...
IDEA - please take another look and enhance the NR DSP function further. I can only comment on CW but it seems to reduce the signal as well as the noise. Often the CW signal I am trying to copy fades to the point I can't use the NR. Ideally it should reduce the noise without significantly affecting the CW signal although some distortion/coloring would be acceptable.
Others that have feedback on SSB or other modes, please add your comments.
If this idea gets enough votes, then hopefully it will make it to the road map again....
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
Regards, Al / NN4ZZ
37
Before I got my 1500 and then the 6500 I used the NR function on my Kenwood TS-590 all the time. It really helped clear out the hash on working weak SSB DX signals. I sure would like to see it working on my 6500. The label, box or whatever you call them is already there. But now it doesn't do anything.
OB O'Brien
W4HXJ1
- 418 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
