Unable to connect to D4Zero with mobile network
flyham
flyham Member ✭✭
I recently got set up with D4zero (zerotier) to enable remote connection to my flex on Starlink connection. I am unable to connect to my station using T mobile on my phone or iPad using the SmartSDR iOS app. The “non smartlink” LAN radio connection is on the radio list but when I click it nothing happens. The connection seems to be totally block by T mobile. I can connect to the radio remotely from my parents WiFi. Is there any way to work around this? Have others successfully used different mobile providers other than T mobile?
Thank you for any insight on this
  • flyham
    flyham Member ✭✭
    I believe I have found a solution. VPN super. If I run it in conjunction with zerotier I am able to connect on 5G T mobile. Shoutout to David Peterson for his helpful post about this on FB
  • Doug - W3UB
    Doug - W3UB Member ✭✭
    How can you run two VPNs at the same time, ZeroTier and VPN Super … it seems not really possible. Is that really what you are doing? On what OS?
