Unable to connect to D4Zero with mobile network
I recently got set up with D4zero (zerotier) to enable remote connection to my flex on Starlink connection. I am unable to connect to my station using T mobile on my phone or iPad using the SmartSDR iOS app. The “non smartlink” LAN radio connection is on the radio list but when I click it nothing happens. The connection seems to be totally block by T mobile. I can connect to the radio remotely from my parents WiFi. Is there any way to work around this? Have others successfully used different mobile providers other than T mobile?
Thank you for any insight on this
I believe I have found a solution. VPN super. If I run it in conjunction with zerotier I am able to connect on 5G T mobile. Shoutout to David Peterson for his helpful post about this on FB
How can you run two VPNs at the same time, ZeroTier and VPN Super … it seems not really possible. Is that really what you are doing? On what OS?
- 691 The Flea Market
- 197 SmartSDR+
- 462 SmartSDR for Mac
- 114 Aurora
- 979 Genius Products
- 136 Antenna Genius
- 323 Shack Infrastructure
- 228 Networking
