New Aruora Purchase
Would appreciate help recommendations on what additional hardware is required/necessary, particularly for remote operations.
Recommended microphone and headset.
What about the remote relay requirement to power/boot the system remotely
Thought on a remote antenna disconnect.
Any other recommendations?
Best method of acquiring the IOS Apple version of the SDR software
I am sure all of these items are addressed within this community, but I would appreciate it if anyone could respond to these.
Many thanks
Clive. (KE2IXD). formally WA2RVS, ZS6BOF
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsTell us more about remote:
- Antennas
- Rotator
- How close is it to visit it if you need to visit it
- Do you want to monitor the RF power out
- Will you be doing digital operations
Once we know a bit more of the bigger picture we have a lot of ideas to help you out.
For remote power control on the high-end look up Digital Loggers. They have a Web controlled outlet device that works great. I have 6 of them here in the house.
One thing I've learned about remote is KISS. Keep it as simple as you can. Less to fail. Less to cause you to drive to the remote site. And be redundant when you can.
From my perspective, I'd leave all the power monitoring in the Aurora. I donno if you have a beam but that might need a controller you can fiddle with remote.
But you need the ability to power cycle things and the digital loggers devices have nice scripting and automatic cycling. They can even cycle plugs automatically if a ping to remote address fails.
To my knowledge this is not much on remote antenna disconnect. I had to build my own here at my home. The fact of the matter is this: Direct lightning strike, there is nothing that is gonna save your antenna and maybe your gear. A near by strike, having a disconnect might save you but obviously it has to be disconnected at the time of the strike.
During the summer I probably connect and disconnect my system here at home twice a day when storms roll through.
The iOS version of SmartSDR is available on the Apple App store. That being said, I am not sure you will find working remote over a phone to be rewarding. The interface is just kind of small. An iPad is a little better. I use a MacBookPro and it works great. Small enough to tote about, powerful and big enough to be useful.
The speakers and mic on the MacBookPro are good enough to use remote. If you want a headset and mic you can go with a USB based Bose or Jabra headset. For these your PTT is on the iPad or computer.
I don't have a Maestro so that will probably change your Mic requirements. But I have oped voice with just my MacBookPro and a Jabra headset without any issue and had good reports.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI have moved everything over to the SRS Station Controller. Very versatile.
The mac, i-pad, i-phone apps are available in the Apple store for purchase. One purchase covers all the devices using the same Apple account.
Thanks for the feedback/responses. In my case the Aurora will be located in my home QTU (Princeton NJ) but I travel a toned spend long periods out of state. So I am looking for the simplest and most reliable systems so that I can operate remotely using a Mac, iPad and the Maestro. So primarily a means to power down the Flex when not in use and remotely disconnecting the antenna (lightning protection)
Much appreciated0 -
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptions- Add a lightning protection system
- You can use any Internet of Thing switch you can find on Amazon to turn it on and off
- I would leave a Windows PC running local to the radio that you can remotely access just in case you need to do some radio maintenance or want to run digital modes without risk of the digital audio stream over the internet being corrupted in transport. I very highly recommend this and explain where here:
- 691 The Flea Market
- 197 SmartSDR+
- 462 SmartSDR for Mac
- 113 Aurora
- 978 Genius Products
- 136 Antenna Genius
- 323 Shack Infrastructure
- 228 Networking
