I'm confused on full duplex with the 8400 and a transverter
Was wanting to pick up a Q5 multiband transverter. If I connect an antenna to RX-A on the back of the 8400, can I transmit via XVTA on 2m and receive on RX-A on 70cm at the same time or vice versa?
Or did I buy the wrong radio?
    Answer ✓
    No as they both use the same hardware. You require a FLEX-6700, 6600(M), 8600(M) or an AU-520(M) to do full duplex.
  • biggen
    biggen Member ✭✭
    edited July 29
    Bummer. Thanks Mike.
    Can the 8600 do full duplex on the same XVTA input? So if I was using a dual band ant running to a single Q5, could I then do what I want, or would I still need a dedicated receive ant connected to the 8600?
  • Rick N0VT
    Rick N0VT Member ✭✭✭
    edited July 29
    Your Flex covers 160-6 meters. You can't throw up an antenna and recieve 70cm without converting it to a frequency your radio can handle. If you want transmit on 2M and recieve on 70CM (such as satellite work) it requires 2 transverters, one for each band. And as Mike said, you can't do that with an 8400.
  • biggen
    biggen Member ✭✭
    Yup, I'm not sure why I thought I could do that.
    Alright, I ordered a Q5 multiband. I guess the dream of full duplex will have to wait.
    No. You need 2 unique transverters still. You can run 2 transverters on the same Transverter port with different IF frequencies such as 28Mhz and 50Mhz and I do that today. I use a diplexor to isolate the hi and low IF. But, you can't do full duplex even with that configuration.
  • biggen
    biggen Member ✭✭
    Alright, thanks guys. I think it may just be easier to get a second inexpensive 2m/70cm rig if I truly want to run full duplex. It wouldn't be in the flex ecosystem, but it would be a heck of a lot cheaper than another 8400 plus another Q5 multiband transverter.
