I'm confused on full duplex with the 8400 and a transverter
Or did I buy the wrong radio?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsNo as they both use the same hardware. You require a FLEX-6700, 6600(M), 8600(M) or an AU-520(M) to do full duplex.
Bummer. Thanks Mike.
Can the 8600 do full duplex on the same XVTA input? So if I was using a dual band ant running to a single Q5, could I then do what I want, or would I still need a dedicated receive ant connected to the 8600?0 -
Your Flex covers 160-6 meters. You can't throw up an antenna and recieve 70cm without converting it to a frequency your radio can handle. If you want transmit on 2M and recieve on 70CM (such as satellite work) it requires 2 transverters, one for each band. And as Mike said, you can't do that with an 8400.
Yup, I'm not sure why I thought I could do that.
Alright, I ordered a Q5 multiband. I guess the dream of full duplex will have to wait.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsCan the 8600 do full duplex on the same XVTA input? So if I was using a dual band ant running to a single Q5, could I then do what I want, or would I still need a dedicated receive ant connected to the 8600?
No. You need 2 unique transverters still. You can run 2 transverters on the same Transverter port with different IF frequencies such as 28Mhz and 50Mhz and I do that today. I use a diplexor to isolate the hi and low IF. But, you can't do full duplex even with that configuration.
- 691 The Flea Market
- 197 SmartSDR+
- 461 SmartSDR for Mac
- 113 Aurora
- 349 FLEX-8000 Signature Series
- 976 Genius Products
- 483 Power Genius XL Amplifier
- 323 Shack Infrastructure
- 228 Networking
- 146 Contesting
