New Flexradio user setup for WSJTX and Ham Radio Deluxe
john.yeagermt
Hello all,
I have been working on getting all of the apps I used with my ICOM radio setup with my Aurora. I have WSJTX and the radio communicating and working but when I get a completed contact on WSJTX it is not logging it in HRD. I have read and followed the setup from posts on the community forum but to this point nothing I try is working. One post I read said that using slicemaster was the cleanest. UDP ports in WSJTX and HRD match up with the default port. I am running WSJTX ver 3.1 and HRD version v6.9.Ø.18172. I used Gridtracker in the past too and I can't get the data from WSJTX to send to Gridtracker either. My gut says I am possibly missing a CAT port setup for the Aurora but at this point I am not sure of that either. I have a CAT port setup for HRD, WSJTX slice A, Slice A, and PTT.
I can post screenshots if need be but on the initial post I am not seeing a way to do so.
Thanks for the help.
John
NZ7W
John
NZ7W
Hi John, This might help
Ham Radio Deluxe - WSTJ-X - SmartSDR 4.2.2 — FlexRadio Community
If this link does not work you will find posting in the Community Category, I should have put it in the 3rd Party software category. Maybe a moderator could move it
Cheers
Ron
VK4JE
Thank you Ron. I will give the settings a go!
- 691 The Flea Market
- 197 SmartSDR+
- 462 SmartSDR for Mac
- 113 Aurora
- 978 Genius Products
- 136 Antenna Genius
- 323 Shack Infrastructure
- 228 Networking
