anyone know of a good Ethernet switch use with the 6700
Propguy
looking for a good Ethernet switch, any recomendations out there Thxs Paul n6voy
Best Answers
I use , after trouble with netgear, an older Cisco SG200-18 , perfect.
Hi Propguy,
Based on a recommendation from Tim some years ago I bought and am using a TP-Link TL-SG1024DE Ethernet Switch with my 6700. Besides being a good switch at a reasonable cost it's "managed" so I can monitor what's going which has been very valuable in debugging various issues.
GL Russ KR6W
Sounds great thanks for the info, have fun on the air
Great thanks so much. Paul0
I remember I had problems with my 6500 and Maestro, turned out having a 1Gb switch/router was not optimal nor needed. A 100 Mb proved to work much better. Right now I use a managed switch and programmed the ports used by Flex to be 100 Mb.
