anyone know of a good Ethernet switch use with the 6700
Propguy
Propguy Member ✭✭
looking for a good Ethernet switch, any recomendations out there Thxs Paul n6voy
Best Answers
  • Ha Gei
    Ha Gei Member ✭✭✭
    Answer ✓
    I use , after trouble with netgear, an older Cisco SG200-18 , perfect.
  • Russ Ravella
    Russ Ravella Member ✭✭✭
    Answer ✓
    Hi Propguy,
    Based on a recommendation from Tim some years ago I bought and am using a TP-Link TL-SG1024DE Ethernet Switch with my 6700. Besides being a good switch at a reasonable cost it's "managed" so I can monitor what's going which has been very valuable in debugging various issues.
    GL Russ KR6W
  • Propguy
    Propguy Member ✭✭
    Answer ✓
    Sounds great thanks for the info, have fun on the air
  • Propguy
    Propguy Member ✭✭
    Great thanks so much. Paul
  • Lasse SM5GLC
    Lasse SM5GLC Member ✭✭✭
    I remember I had problems with my 6500 and Maestro, turned out having a 1Gb switch/router was not optimal nor needed. A 100 Mb proved to work much better. Right now I use a managed switch and programmed the ports used by Flex to be 100 Mb.
