anyone know of a good Ethernet switch use with the 6700
Propguy
looking for a good Ethernet switch, any recomendations out there Thxs Paul n6voy
Best Answers
I use , after trouble with netgear, an older Cisco SG200-18 , perfect.
Sounds great thanks for the info, have fun on the air
Great thanks so much. Paul0
Hi Propguy,
Based on a recommendation from Tim some years ago I bought and am using a TP-Link TL-SG1024DE Ethernet Switch with my 6700. Besides being a good switch at a reasonable cost it's "managed" so I can monitor what's going which has been very valuable in debugging various issues.
GL Russ KR6W
I remember I had problems with my 6500 and Maestro, turned out having a 1Gb switch/router was not optimal nor needed. A 100 Mb proved to work much better. Right now I use a managed switch and programmed the ports used by Flex to be 100 Mb.
- 681 The Flea Market
- 393 SmartSDR API
- 98 Aurora
- 991 Maestro
- 964 Genius Products
- 479 Power Genius XL Amplifier
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
