PocketSDR for Android - Native Flex 6000/8000/Aurora client
PocketSDR is now available on the Google Play and Amazon AppStore for your favorite Android devices.
This is a native FlexRadio Android client written from the ground up. This initial release has quite a few features but we will be adding more shortly including FT8/FT4/JT modes support, PSK, Logbook, and more!
Download from Google Play: https://play.google.com/store/apps/details?id=com.hamshackventures.apps.pocketsdr
Download from Amazon Appstore (Kindle Fire tablets): https://www.amazon.com/gp/product/B0H4BF4PRT
I hope you have as much fun using it as I had developing it.
73, Ria, N2RJ
Working great for me. I'm anxious to play with it some more.
Is there a way to minimize the slice flag to just frequency?
73, Pat KØPC
hi Pat
double tap slice flag and it turns into a mini flag.
Work great on mt phone s25 from samsung but not shows update on my samsung tablet 7 inch
Thxs fir the work
Ria,
Many thanks for the great application, as it's working very nicely.
Is there a place we should send you comments for things we may find or wish list options etc… ?
ie.. adding FDVU and FDVL to the mode selections for FreeDV. :)
All the best, and this really is very much appreciated, as many of us have been waiting a very long time to take advantage of our Android devices.
Tnx, Walter/K5WH
Hi Walter,
You can email them to me - ria@n2rj.com or support@hamshackventures.com. I create feature request tickets for each one.
If you post them here, no problem too but it may take longer as I don't check here that often.
Ria
We have a facebook group for support: https://www.facebook.com/groups/988285760611083
Support also via email - support@hamshackventures.com
Please announce any app updates here … some of don't do FB …
Thanks much for the hard work on this.I will jump on it as soon as i get some time,and play with it.
Bugfix release going out hopefully today. Has a few important fixes including better Bluetooth device selection, tuning fixes, and radio discovery logic. Will be in the Play Store and Amazon.
Also has an audio level calibration feature - set perfect audio levels per device easily.
Tuning step to 1kHz, and snap tuning step
Bugfix 26.6.1-19 is live on Google Play and Amazon Appstore.
MIDI CW paddles also work in progress. Works but at low speed. Will also have a HaliKey serial to work on serial port CW.
I'll be headed off to Germany next week so I expect the next release to be soon after I return.
Changelog:
Radio Startup And Profiles- Fixed profile reload/startup behavior so the active profile state is applied more reliably.
- Improved panadapter drag/tune behavior to avoid jumping back to center while dragging.
- Improved remembered display/audio/settings restoration across reconnects.
Aurora / Meters / UI
- Added or refined Aurora-related meter/status handling.
- Polished several control layouts and UI behaviors.
- Hid FM-incompatible DSP/noise-reduction controls from FM slices and slice flags.
Audio
- Added/refined local mic calibration.
- Mic calibration now samples from a 0 dB baseline before calculating saved gain.
- Improved audio device handling and Bluetooth audio recovery.
- Added better persistence/handling for audio-related settings.
FM / Repeater / Memories
- Fixed FM repeater offset restore so stored offset state is applied properly.
- Improved repeater-related restore behavior after reconnect/startup.
Discovery / Connection
- Fixed LAN rediscovery: stale radios can disappear, and if they come back with the same announce payload they now reappear.
- Added deterministic SmartSDR license refresh after startup, with retry, which fixed Fire tablet license fields staying Pending.
- Expanded SmartSDR license parsing for newer/FlexLib field names.
Controllers
- Added PTT support for MIDI controllers (eg HaliKey).
Next update will have a logbook feature.
How would you like to use your logbook? My idea is it's for portable remote and then offload the log to a main log on a computer or QRZ etc.
I am also figuring out FreeDV. I would like for it to be available for all radios. I understand there's some need to use a docker container for 6000 series?
Hi Ria,
Thats the Logbook use I invision I will need for my portable operations.
So regarding FreeDV, it looks like it's just a matter of turning on FDV mode, and all setup is done with PC/Mac clients. I'll see if I can include this in the next release.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
