PocketSDR for Android - Native Flex 6000/8000/Aurora client
Ria
Ria Member ✭✭✭
PocketSDR is now available on the Google Play and Amazon AppStore for your favorite Android devices.
This is a native FlexRadio Android client written from the ground up. This initial release has quite a few features but we will be adding more shortly including FT8/FT4/JT modes support, PSK, Logbook, and more!
Download from Google Play: https://play.google.com/store/apps/details?id=com.hamshackventures.apps.pocketsdr
Download from Amazon Appstore (Kindle Fire tablets): https://www.amazon.com/gp/product/B0H4BF4PRT
I hope you have as much fun using it as I had developing it.
73, Ria, N2RJ
  • Pat KØPC
    Pat KØPC Member ✭✭
    Working great for me. I'm anxious to play with it some more.
    Is there a way to minimize the slice flag to just frequency?
    73, Pat KØPC
  • Ria
    Ria Member ✭✭✭
    hi Pat
    double tap slice flag and it turns into a mini flag.
  • amsnl
    amsnl Member ✭✭
    Work great on mt phone s25 from samsung but not shows update on my samsung tablet 7 inch
    Thxs fir the work
  • K5WH
    K5WH Member ✭✭
    Ria,
    Many thanks for the great application, as it's working very nicely.
    Is there a place we should send you comments for things we may find or wish list options etc… ?
    ie.. adding FDVU and FDVL to the mode selections for FreeDV. :)
    All the best, and this really is very much appreciated, as many of us have been waiting a very long time to take advantage of our Android devices.
    Tnx, Walter/K5WH
  • Ria
    Ria Member ✭✭✭
    Hi Walter,
    You can email them to me - ria@n2rj.com or support@hamshackventures.com. I create feature request tickets for each one.
    If you post them here, no problem too but it may take longer as I don't check here that often.
    Ria
  • Ria
    Ria Member ✭✭✭
    We have a facebook group for support: https://www.facebook.com/groups/988285760611083
    Support also via email - support@hamshackventures.com
  • Doug - W3UB
    Doug - W3UB Member ✭✭
    Please announce any app updates here … some of don't do FB …
  • n0ypd
    n0ypd Member ✭✭
    Thanks much for the hard work on this.I will jump on it as soon as i get some time,and play with it.
  • Ria
    Ria Member ✭✭✭
    edited June 16
    Bugfix release going out hopefully today. Has a few important fixes including better Bluetooth device selection, tuning fixes, and radio discovery logic. Will be in the Play Store and Amazon.
    Also has an audio level calibration feature - set perfect audio levels per device easily.
    Tuning step to 1kHz, and snap tuning step
  • Ria
    Ria Member ✭✭✭
    edited June 17
    Bugfix 26.6.1-19 is live on Google Play and Amazon Appstore.
    MIDI CW paddles also work in progress. Works but at low speed. Will also have a HaliKey serial to work on serial port CW.
    I'll be headed off to Germany next week so I expect the next release to be soon after I return.
    Changelog:
    Radio Startup And Profiles
    • Fixed profile reload/startup behavior so the active profile state is applied more reliably.
    • Improved panadapter drag/tune behavior to avoid jumping back to center while dragging.
    • Improved remembered display/audio/settings restoration across reconnects.
    Aurora / Meters / UI
    • Added or refined Aurora-related meter/status handling.
    • Polished several control layouts and UI behaviors.
    • Hid FM-incompatible DSP/noise-reduction controls from FM slices and slice flags.
    Audio
    • Added/refined local mic calibration.
    • Mic calibration now samples from a 0 dB baseline before calculating saved gain.
    • Improved audio device handling and Bluetooth audio recovery.
    • Added better persistence/handling for audio-related settings.
    FM / Repeater / Memories
    • Fixed FM repeater offset restore so stored offset state is applied properly.
    • Improved repeater-related restore behavior after reconnect/startup.
    Discovery / Connection
    • Fixed LAN rediscovery: stale radios can disappear, and if they come back with the same announce payload they now reappear.
    • Added deterministic SmartSDR license refresh after startup, with retry, which fixed Fire tablet license fields staying Pending.
    • Expanded SmartSDR license parsing for newer/FlexLib field names.
    Controllers
    • Added PTT support for MIDI controllers (eg HaliKey).
  • Ria
    Ria Member ✭✭✭
    edited June 18
    Next update will have a logbook feature.
    How would you like to use your logbook? My idea is it's for portable remote and then offload the log to a main log on a computer or QRZ etc.
    I am also figuring out FreeDV. I would like for it to be available for all radios. I understand there's some need to use a docker container for 6000 series?
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    Hi Ria,
    Thats the Logbook use I invision I will need for my portable operations.
  • Ria
    Ria Member ✭✭✭
    So regarding FreeDV, it looks like it's just a matter of turning on FDV mode, and all setup is done with PC/Mac clients. I'll see if I can include this in the next release.
  • JohnT
    JohnT Member ✭✭
    Thank you for the App! Using it with my 8600M.
    I have one question:
    It appears to me that when I select Tune, it always turns on the ATU in the Flex Radio? I have an external tuner which I use, so is there a way to prevent it from enabling the internal tuner?
    Hi John, I just looked, and you are right. I will add an issue to the GitHub repository.
  • JohnT
    JohnT Member ✭✭
    edited August 1
    Thank you Len!
    73 John N2KBE
  • Ria
    Ria Member ✭✭✭
    Regarding the tune button, I've confirmed this and a fix should be out in the next release. The ATU doesn't activate but the status button does. It shouldn't so I'll fix that behavior.
    Thanks Ria!
  • JohnT
    JohnT Member ✭✭
    I have noticed that when the PROC is disabled, the Compression Meter still shows compression taking place.
    I have also noticed that the Level Meter shows microphone audio even if I have the feature disabled (Radio Settings PHONE - Level During RX Disabled).
  • mnewbill
    mnewbill Member ✭✭
    what happened to this?
  • mnewbill
    mnewbill Member ✭✭
    hi, I just found this on Google Play. I guess its not listed very high up on their search. I had to find it by directly searching for it. kind of makes sense since its a niche market on here.
    that being said, I really like the app.
    How do we report the bugs or suggestions etc?
    Have 3 comments at this point:
    On my older android tablet, the memory channels list seems to be truncated, and some of the memory are not in the list even when I scroll. interesting, and not sure if that is even relevant since the android version on that tablet is probably not supported anyway.
    the ptt button is small on my s22 galaxy phone, and only usable with the lock on feature active. if I try to use it holding the button, the tx drops randomly as my finger twitches at all. the way the ios version handles this is you press, and move your finger anywhere on the screen, it holds the tx on until you remove your finger from the screen, regardless if the button moved, for example, if screen rotation happens, it don't break tx. that would be an improvement if possible on android.
    comment 3: power usage. the cpu is really working hard? it seems, and the battery on my phone looks like 1 hour max from full charge to dead- it drops a percent per minute or two it seems. I don't know how much better it gets if I turn off the screen, but are there any thoughts to reduce power usage? can it have a "lite mode" to enhance battery usage somehow? thought it was the cell data usage doing it, but seems similar when on wifi as well.
    Thanks and great app, it is really nice to have everything I need to talk in the phone alone now.
    k4kfi
  • Ria
    Ria Member ✭✭✭
    PocketSDR app - native Android client for FlexRadio FLEX-6000 and FLEX-8000 radios.
    New release 51 (26.10.1-1) headed to the play store. It should update on your device automatically.
    https://play.google.com/store/apps/details?id=com.hamshackventures.apps.pocketsdr&pli=1
    NEW features:
    Logbook, complete with country prefix lookup and ADIF export. This is a simple logbook to log contacts and not intended to replace your main logbook.
    Tuner Genius XL support, direct connect and SmartSDR API. You can now control your Tuner Genius XL directly from the app. Supports SO2R and 1x3. It will auto detect which version you have. However consider this feature to be beta, a work in progress.
    Fixes and enhancements:
    Audio and performance enhancements.
    Optimized PTT delay, but this ultimately depends on network latency at your location. I’ve tested it as far away as Japan, and the delay was minor.
    NOTE: FDVU/FDVL for FreeDV may or may not work, I am actively looking at getting it to where it needs to be. It's there in the menu, however. Any feedback is welcome.
    As always I'm here for you, and I will have a follow up release to tighten up some of these issues.
    Ria
  • Ria
    Ria Member ✭✭✭
    So yes it is being actively developed and I just pushed a release build.
    Support is via the support email in the app. support@hamshackventures.com. We also have a facebook group - pocketSDR users.
    Send me some screenshots of where things are being cut off.
    There is a low power mode under the display menu. It also auto throttles with different devices. The latest release I have made some improvements with battery usage. My main test device is a pixel 10 and i also run a samsung A11+ and also some amazon devices.
    If you have an Android device, I highly recommend this app. I run it on my 5 year old Android Motorola Edge phone and it works great! I have tried other methods for operating remotely from my phone, and they are just not easy or pleasant to use. PocketSDR packs all of the Flex features into a really nice interface that is easy to read and easy to operate.
  • Ria
    Ria Member ✭✭✭
    New release posted, now with FT8 and FT4 support!
    There is a new FT mode button on the left side menu.
    Additionally:
    • Local logbooks now use a more reliable SQLite database
    • Existing logbook entries migrate automatically
    • Optional automatic ADIF backup to local storage or Google Drive
    • Local and external log databases are now kept separate
    • ADIF 3.1.8 compliance improvements for dates, modes, and split frequencies
    • Correct SSB, FT4, FT8, and FreeDV mode/submode exports
    • Older PocketSDR ADIF files remain import-compatible
    • Manual contacts logged during FT operation now correctly use FT8 or FT4 instead of DIGU
    Existing users can update (or auto update from Play or Amazon store)
    new users download here: https://play.google.com/store/apps/details?id=com.hamshackventures.apps.pocketsdr
