PocketSDR for Android - Native Flex 6000/8000/Aurora client
Ria
Ria Member ✭✭✭
PocketSDR is now available on the Google Play and Amazon AppStore for your favorite Android devices.
This is a native FlexRadio Android client written from the ground up. This initial release has quite a few features but we will be adding more shortly including FT8/FT4/JT modes support, PSK, Logbook, and more!
Download from Google Play: https://play.google.com/store/apps/details?id=com.hamshackventures.apps.pocketsdr
Download from Amazon Appstore (Kindle Fire tablets): https://www.amazon.com/gp/product/B0H4BF4PRT
I hope you have as much fun using it as I had developing it.
73, Ria, N2RJ
  • Pat KØPC
    Pat KØPC Member ✭✭
    Working great for me. I'm anxious to play with it some more.
    Is there a way to minimize the slice flag to just frequency?
    73, Pat KØPC
  • Ria
    Ria Member ✭✭✭
    hi Pat
    double tap slice flag and it turns into a mini flag.
  • amsnl
    amsnl Member ✭✭
    Work great on mt phone s25 from samsung but not shows update on my samsung tablet 7 inch
    Thxs fir the work
  • K5WH
    K5WH Member ✭✭
    Ria,
    Many thanks for the great application, as it's working very nicely.
    Is there a place we should send you comments for things we may find or wish list options etc… ?
    ie.. adding FDVU and FDVL to the mode selections for FreeDV. :)
    All the best, and this really is very much appreciated, as many of us have been waiting a very long time to take advantage of our Android devices.
    Tnx, Walter/K5WH
  • Ria
    Ria Member ✭✭✭
    Hi Walter,
    You can email them to me - ria@n2rj.com or support@hamshackventures.com. I create feature request tickets for each one.
    If you post them here, no problem too but it may take longer as I don't check here that often.
    Ria
  • Ria
    Ria Member ✭✭✭
    We have a facebook group for support: https://www.facebook.com/groups/988285760611083
    Support also via email - support@hamshackventures.com
  • Doug - W3UB
    Doug - W3UB Member ✭✭
    Please announce any app updates here … some of don't do FB …
  • n0ypd
    n0ypd Member ✭✭
    Thanks much for the hard work on this.I will jump on it as soon as i get some time,and play with it.
  • Ria
    Ria Member ✭✭✭
    edited June 16
    Bugfix release going out hopefully today. Has a few important fixes including better Bluetooth device selection, tuning fixes, and radio discovery logic. Will be in the Play Store and Amazon.
    Also has an audio level calibration feature - set perfect audio levels per device easily.
    Tuning step to 1kHz, and snap tuning step
  • Ria
    Ria Member ✭✭✭
    edited June 17
    Bugfix 26.6.1-19 is live on Google Play and Amazon Appstore.
    MIDI CW paddles also work in progress. Works but at low speed. Will also have a HaliKey serial to work on serial port CW.
    I'll be headed off to Germany next week so I expect the next release to be soon after I return.
    Changelog:
    Radio Startup And Profiles
    • Fixed profile reload/startup behavior so the active profile state is applied more reliably.
    • Improved panadapter drag/tune behavior to avoid jumping back to center while dragging.
    • Improved remembered display/audio/settings restoration across reconnects.
    Aurora / Meters / UI
    • Added or refined Aurora-related meter/status handling.
    • Polished several control layouts and UI behaviors.
    • Hid FM-incompatible DSP/noise-reduction controls from FM slices and slice flags.
    Audio
    • Added/refined local mic calibration.
    • Mic calibration now samples from a 0 dB baseline before calculating saved gain.
    • Improved audio device handling and Bluetooth audio recovery.
    • Added better persistence/handling for audio-related settings.
    FM / Repeater / Memories
    • Fixed FM repeater offset restore so stored offset state is applied properly.
    • Improved repeater-related restore behavior after reconnect/startup.
    Discovery / Connection
    • Fixed LAN rediscovery: stale radios can disappear, and if they come back with the same announce payload they now reappear.
    • Added deterministic SmartSDR license refresh after startup, with retry, which fixed Fire tablet license fields staying Pending.
    • Expanded SmartSDR license parsing for newer/FlexLib field names.
    Controllers
    • Added PTT support for MIDI controllers (eg HaliKey).
  • Ria
    Ria Member ✭✭✭
    edited June 18
    Next update will have a logbook feature.
    How would you like to use your logbook? My idea is it's for portable remote and then offload the log to a main log on a computer or QRZ etc.
    I am also figuring out FreeDV. I would like for it to be available for all radios. I understand there's some need to use a docker container for 6000 series?
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    Hi Ria,
    Thats the Logbook use I invision I will need for my portable operations.
  • Ria
    Ria Member ✭✭✭
    So regarding FreeDV, it looks like it's just a matter of turning on FDV mode, and all setup is done with PC/Mac clients. I'll see if I can include this in the next release.
  • JohnT
    JohnT Member ✭✭
    Thank you for the App! Using it with my 8600M.
    I have one question:
    It appears to me that when I select Tune, it always turns on the ATU in the Flex Radio? I have an external tuner which I use, so is there a way to prevent it from enabling the internal tuner?
    Hi John, I just looked, and you are right. I will add an issue to the GitHub repository.
  • JohnT
    JohnT Member ✭✭
    edited August 1
    Thank you Len!
    73 John N2KBE
