Can someone help with MRP40
Hi Bruce,
I think you want to do CW and not transmit the CW audio tone in SSB over DAX.
To do this, your configuration needs to be slightly different.
First, a Winkeyer must be created in SmartCat.Then set WinKey as the send option in MRP.
and switch to bug mode!
vy73 55 Klaus2 -
Klaus.....thank you so much for helping me with this.Got it working perfectly this morning. I believe this will help a lot of people with Flex Radios, that have this program and cannot get it working.
Bruce KO4UHL2 -
Hi Bruce,
Could you please tell me which version of MRP40 you are using. It appears that there are a few versions and I'm not sure of which one is compatible with the recent Flex updates, particularly to DAX.
Tnx es 73 de Mike N2YBB0 -
Hi Klaus-
Could you please tell me which version of MRP40 you are using. It appears that there are a few versions and I'm not sure of which one is compatable with the recent Flex updates, particularly to DAX.
Hi Mike,
my MRP 40 is the latest Version MRP4067
and it works very well with SmartSDR 4.2.20.here my configuration
73 Klaus
I paid for this app a few years ago and had it running on a win 10 PC that I no longer have. After following this thread I decided to install and try it again on my new win 11 machine. Is it just me or does one have to jump thru hoops to get this program to install properly- the instructions are quite detailed but seem way more involved then the average ham program install. I made a valid attempt to follow his steps but still failed. The program did not wind up in the x86 program folder it was suppose to and when I did find the exe folder - it would not run.
Any hints or suggestions in just getting installed and running on a Win11 PC/
73 Paul w2eck
Hi Paul,
No, unfortunately there's no easy way.
Because of Microsoft's restrictions, the lengthy process described is necessary.
Perhaps there's a string in the program that's being detected as a virus or something similar.
Or maybe the program needs to access areas that Microsoft considers off-limits.
You have to follow the instructions exactly, since the browsers are also restricting us.73 Klaus DF3RP
Hi Klaus-
Thank you very much for answering my plea. Using the information in your instruction I was able to install MRP40. It is working on my Flex8400m in both RX and TX.
My Vy 73 de Mike N2YBB0
- 685 The Flea Market
- 102 Aurora
- 994 Maestro
- 970 Genius Products
- 357 Tuner Genius XL
