Is SmaertLink down?
Bob G   W1GLV
Bob G W1GLV Member ✭✭
No response from SmartLink using my AT&T Hotspot. Use to work real well.
  • Mike Webb KC0YHM
    Mike Webb KC0YHM Member ✭✭
    edited September 2018
    GM Bob. SmartLink has been wierd for me the last few days. Clicking CONNECT is not enough. I find that I need to go to SETUP and test the connection...it always passes...then try connecting again and it will connect.
    edited April 2019
    Works for me.
  • Mike Webb KC0YHM
    After Mikes reply... I clicked CONNECT and waited...and...instead of the nearly instant respone I had been getting the radio did come up but it took a minute and thirty seconds. Once it connects everything is business as usual.
  • Bob G   W1GLV
    edited June 2020
    Rechecked the SmartLink setup and found out I had been unregistered. Not of my doing. Reregistered, manually forwarded the ports and everything is working correctly. Thanks to everyone that answered my request. 73's and good hamming.
  • W4AFK Bruno
    W4AFK Bruno Member ✭✭
    edited June 14
