DAX and N1MM
Mark Griffin
Member ✭✭✭
Guys,
I will be using N1MM for the WPX CW Contest this weekend.
But I notice on the DAX that nothing is showing up in the receive streams for Slice A or Slice B. Did they do something to DAX with N1MM that would not be causing that to work?
When I transmit it does transmit. Is there some setting that I am missing in the Setup?
Mark KB3Z
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIf you are using SmartSDR 4.2.18 you will need to reconfigure anything that uses DAX audio 'endpoints' as the naming changed.
So If I was using SSB Audio files yes, but otherwise nothing needs to be done.
Mark
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIf you are decoding CW, you will also need to make changes.
I am not decoding CW with N1MM Mike. I believe there is a program that works with N1MM to do that, but I don't use it.
