DAX and N1MM
Mark Griffin
Member ✭✭✭
Guys,
I will be using N1MM for the WPX CW Contest this weekend.
But I notice on the DAX that nothing is showing up in the receive streams for Slice A or Slice B. Did they do something to DAX with N1MM that would not be causing that to work?
When I transmit it does transmit. Is there some setting that I am missing in the Setup?
Mark KB3Z
If you are using SmartSDR 4.2.18 you will need to reconfigure anything that uses DAX audio 'endpoints' as the naming changed.
So If I was using SSB Audio files yes, but otherwise nothing needs to be done.
Mark
If you are decoding CW, you will also need to make changes.
I am not decoding CW with N1MM Mike. I believe there is a program that works with N1MM to do that, but I don't use it.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
