PGXL wont go to standby
Jim Altman
Member ✭
This morning, the PGXL utility won't connect. Powerup runs all the self tests and all reports ok, but then does not change to standby. The screen reports DHCP has an IP address. If i press the operate/standby button it goes into operate and works just fine. Press the operate/standby button again it goes back to the self test screen. I have restarted, unplugged and left it sit a bit, reset the network router but no change in this. I can ping the IP address just fine. The startup screen of the utility reports the correct ip address, but does not connect.
It looks like the self-test gets stuck after completing the tests and does not finish to get to standby, Every other thing on the network is fine and internet access is fine.
Oh, I did the factory reset procedure but no change.
No other Flex equipment, just the PGXL.
Any suggestions?
Thanks and 73, Jim W4UCK
Any suggestions?
support ticket created
Thank you.
73 Jim0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
