Aurora AU-500
cyberkal
Member ✭
This is W6GZG from Fernely, NV. I operate from an assisted living facility and currently use RemoteTX to control an Icom 7300, using a Myantenna end-fed 10-75 MHz antenna. I am interested in increasing my footprint by increasing my output power with an Aurora AU-500. Question: Can I connect it remotely to my Apple iMac via Wi-Fi? At my end, the Wi-Fi is 418 Mbps down and 541 Mbps up. At the transmitter location, the Wi-Fi connection is 300 Mbps using an eero mesh. The average latency is 55MS. I understand I will need a Smart SDR for Mac software for my iMac. Will a Aurora AU-500. Thank you, ****
TNX Mike. I viewed your UK YouTube video. Could remote be possible using a Rapberry inter face with the FlexRadio?
****-W6GZG0
Yes using the SmartLink utility, but the radio is not WiFi enabled and has to be cabled to the router. You can add a gaming WiFi adapter to the radio if required.
Keep in mind that WiFi can be bursty and you might hear the out artifact. As for your upstream, that is more than enough. It is the Jitter numbers that are more critical.
I am not sure what a raspberry interface is?
- 394 Community Topics
- 671 The Flea Market
- 179 SmartSDR+
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 82 Aurora
- 982 Maestro
- 957 Genius Products
- 476 Power Genius XL Amplifier
- 350 Tuner Genius XL
- 131 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
