Does Slice Master work with SmartSDR 4.2.18?
Any ideas?
I completely purged Slice Master from my system, including Firewall rules, app settings folder and a pass through the registry editor. Then I downloaded a fresh copy of the Slice Master distribution zip file and unzipped it into a new folder.
Slice Master is starting without any apparent errors, but when it tries to launch WSJT warnings appear in the SM status bar.
WARNING: DAXIQ channel is not enabled in DAX Control Panel. daxiq=1 slice='A'
This is really odd... When I launch WSJT directly, it connects to DAXIQ-A and the SmartSDR DAX IQ stream shifts from blue to green and indicates Streaming.
What am I missing?0 -
Since the names of the Audio End points changed, SliceMaster can't find them and believes that DAX has not started. You'll have to reach out to the author to make changes.
Thank you Mike,
I noticed the difference, but had not found anyone to confirm... Will follow up accordingly.0 -
Has Flex reached out to the third party software authors to help them with the change? Seems that there is little to no support for what we used in the past? Looks like the software folks are ****, and I don't blame them!
For those of you who are stuck waiting on SliceMaster, I'm sure Don will get to it. The changes are not exactly trivial. I've spent about 2 months getting a workable solution build for myself, called SmartStreamer4 - specifically for the 4.2.18 release and has been tested extensively with 4.1.5.
I just released beta v0.1.19b today, and it includes multiflex support, multiple panadapters and IQ streams. Its currently only built out to support CW Skimmer but if there are other needs like WSJTx I can add over time.
Thank you Chris, works like a champ!
Bob, KO2F
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
