SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
Does Slice Master work with SmartSDR 4.2.18?
Any ideas?
I completely purged Slice Master from my system, including Firewall rules, app settings folder and a pass through the registry editor. Then I downloaded a fresh copy of the Slice Master distribution zip file and unzipped it into a new folder.
Slice Master is starting without any apparent errors, but when it tries to launch WSJT warnings appear in the SM status bar.
WARNING: DAXIQ channel is not enabled in DAX Control Panel. daxiq=1 slice='A'
This is really odd... When I launch WSJT directly, it connects to DAXIQ-A and the SmartSDR DAX IQ stream shifts from blue to green and indicates Streaming.
What am I missing?0 -
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsSince the names of the Audio End points changed, SliceMaster can't find them and believes that DAX has not started. You'll have to reach out to the author to make changes.
Thank you Mike,
I noticed the difference, but had not found anyone to confirm... Will follow up accordingly.0 -
Has Flex reached out to the third party software authors to help them with the change? Seems that there is little to no support for what we used in the past? Looks like the software folks are ****, and I don't blame them!
For those of you who are stuck waiting on SliceMaster, I'm sure Don will get to it. The changes are not exactly trivial. I've spent about 2 months getting a workable solution build for myself, called SmartStreamer4 - specifically for the 4.2.18 release and has been tested extensively with 4.1.5.
I just released beta v0.1.19b today, and it includes multiflex support, multiple panadapters and IQ streams. Its currently only built out to support CW Skimmer but if there are other needs like WSJTx I can add over time.
Thank you Chris, works like a champ!
Bob, KO2F
- 419 Community Topics
- 718 The Flea Market
- 228 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
