Maestro and Flex 6500
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Eric
The Maestro has to first connected to your Wifi network. Have you done that?
Thanks for reply and comments
I understand that. but the 6500 was used connected via the cat (RJ45) cable to the Maestro and all was working fine for several weeks. I obtained it from a SK friend who had used it for several years from new.
As I say it worked fine connected directly with the Maestro then suddenly no radio and the Maestro showed the WIF and associated screen. The 6500 works when used with the PC software so proved that the radio is working, But no comms with direct connection to the Maestro. Thanks, Eric GW8LJJ.0
- 691 The Flea Market
- 197 SmartSDR+
- 462 SmartSDR for Mac
- 113 Aurora
- 978 Genius Products
- 136 Antenna Genius
- 323 Shack Infrastructure
- 228 Networking
