Maestro and Flex 6500
Hi Eric
The Maestro has to first connected to your Wifi network. Have you done that?
Thanks for reply and comments
I understand that. but the 6500 was used connected via the cat (RJ45) cable to the Maestro and all was working fine for several weeks. I obtained it from a SK friend who had used it for several years from new.
As I say it worked fine connected directly with the Maestro then suddenly no radio and the Maestro showed the WIF and associated screen. The 6500 works when used with the PC software so proved that the radio is working, But no comms with direct connection to the Maestro. Thanks, Eric GW8LJJ.0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
