How to control Stepir from remote computer
Burch - K4QXX
Burch - K4QXX Member ✭✭
In playing around with the remote option in 1.4, I am wondering how I can control my Stepir antenna.  I kept having to go into the hamshack to manually move the antenna between band changes.  I know some people on here have been running remote for sometime using 3 party software.  Is anyone doing this with a Stepir?  I use DDUtil to operate the Stepir.
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited September 2018
    I run remote a lot...
    Here is how to control the SteppIR
    1.  Start SmartCAT and SSDR on the Local Computer
    2.  Load DDUTIL onto the Local Computer that controls the SteppIR
    3.  Stop SSDR on the Local Computer
    4.  Leave SmartCAT and DDUTIL running on the Local Computer
    5.  Start SSDR on the Remote Computer
    The SteppIR will now follow frequency on the Remote Computer because it is reading frequency from SMARTCAT on the Remote.
  • Dave -- W7IWW
    Dave -- W7IWW Member ✭✭
    edited June 2018
    Neal Campbell helped me set up this same arrangement and it works perfectly.
  • Burch - K4QXX
    edited July 2018
    Very cool!  Thank you guys.  I will try this tonight when I get home from work.
  • Burch - K4QXX
    edited July 2018
    So I don't need to run DDUTIL on the remote computer?  I was using it on the remote computer for my logging software (HRD).
  • KY6LA_Howard
    edited January 2017
    I haven't tried DDUTIL on my remote yet... but then while i use HRD Logging,  I rarely log contacts unless they are Rare DX...I will try it later today to see if I can run 2 instances of DDUTIL on the same network.
  • W1IMD
    W1IMD Member ✭✭
    For those of us more paranoid types, I have installed a Moxa N5410 IP to 4 serial port server on the network and it can accept up to 4 simultaneous connections. So I can have DDUtil on the local computer and DDUtil on the remote as well. The Moxa software sets up virtual ports on each computer. As Ron Reagan said,  "Trust but verify"
  • KY6LA_Howard
    edited January 2017
    No u don't need ddutil on the remote to control the SteppIR at Local
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited May 2015
    I had to set up DDUTIL with the proper Serial port and to specify the protocol. Having great success with a USB to serial adapter.
  • David Decoons, wo2x
    edited June 2020
    If you only need HRD Logbook & DM780 on the remote computer then why not run MiniDeluxe 2 on the remote computer and DDUtil on local PC for StepIR and other peripheral integration? Dave, wo2x
  • Jim Gilliam
    That is exactly what I am doing. Using DDUtil with a local computer with a USB to serial adapter plugging into the SteppIr serial port.
  • KY6LA_Howard
    edited January 2017
    As a test I just ran DDUTIL on both my Local and Remote Computer
    2 Instances of DDUTIL operating at the same time (one on Local and one on Remote) definitely works OK
    I could run HRD Logbook on my Remote Computer under one instance of DDUTIL
    And the LP-100, rotor, SteppIR on my Local Computer
    It is just too bad the LP-100, Rotor, SteppIR are tied to the Local serial port rather than being Ethernet devices..
    But Heck it will likely take another century to pass before other Ham Manufacturers abandon serial ports and join the 21st century Ethernet...
  • Burch - K4QXX
    edited July 2018
    Howard
    Thanks for your help with this.  StepIR is working great remotely now.
  • Jim Gilliam
    Icom has joined the Ethernet band wagon. My 7800 remotes stand-alone and it can also control the SteippIR through the antiquated CI-V port. It's almost a SmartSDR in that I have an SDR-IQ piggy-backed to it so I get the same panorama as the SmartSDR. However, I prefer the Flex because of its wonderful potential.
    Jim
  • Carl Moreschi
    Carl Moreschi Member
    edited March 2015
    My N4PY Pegasus Plus can run using it's client-server and provide full control for LP-100, rotor, steppir, and various antenna switch boxes.  Also, Pegasus Plus can give full remote CW paddle operation using a K1EL winkey keyer.
  • KY6LA_Howard
    edited March 2015
    Carl
    Thanks for that info.. I plan to download and test it out on remote
    Now if you could only figure out how to put spots into the Spectrum Display (like in NaP3) I would be first in line to buy your product.
  • Runamuk52
    Runamuk52 Member, Unconfirmed
    What is DDUTIL and where do I get it? Also does DDUTIL allow you to turn the rotator or just change bands? If not does anyone have a solution to turn the rotator (Yaesu G-2800) on my DB-42
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    I found the best solution for remote control of the Steppir or Ultra Beam is using PST Roitor AZ.
    I use Node Red. Allows control from any web browser.
    Below pic is screenshot from my iPhone Safari browser. MonstIR currently with no radio connected. I am 5000+ miles away :-)
    When it is adjusting Elements change from Ready to Moving and red LED lights.
    switch to enable/disable Autotrack. I can add fine tuning and band selection for non-Autotrack but didn’t use those controls
    Has controls you need.
    73 Dave wo2x
  • N5NHJ
    N5NHJ Member ✭✭✭
    Another way for controlling the SteppIR is setting the antenna's controller in autotrack mode and connect the Flex to the controller using a USB/serial adapter.
    if you want to connect the SteppIR controller to the Flex, the USB cable guide has info on the cabling needed.
    https://www.flexradio.com/documentation/usb-cable-interface-guide-pdf/
    73 Dave wo2x
